Mobile Menu for the Dahlia Theme
I can’t get the “Get Dahlia” button off of the mobile menu. I have even created an entirely new mobile menu and the “Get Dahlia” button still shows up at the bottom of the menu. How do I delete it?
Let's start creating ⟶
Go into the customizer, Header > then at the bottom of the page select the Tablet / Mobile tab. In the Off Canvas box you can delete the button, or even change it to be whatever you would like. That off Canvas box is everything you will find on the mobile menu.
