Mobile Menu for the Dahlia Theme
I want my mobile & tablet menu to mimick my desktop menu but whenever I click on appearance/customize/mobile and then choose right and left side, my entire desktop menu shows up all wonky. I even have the mobile menu selected when I make these changes, so not sure why this continues to change the desktop menu as well. Please let me know how to fix this issue or what to do. I left my mobile menu for now the way it was because I don’t want my desktop menu messed up. I have tried in the live edit area as well as the appearance/customize area in my wordpress back office. Thank you!
What is your URL to preview what is happening? With the menus in a Kadence theme you have 3. You have a left, right and seperate mobile menu. On desktop you would assign the menus you want to show. Then you create a new menu that you would show on mobile. and that menu gets assigned to the mobile position and then set in the mobile settings in the customizer.
https://avralifestyle.com/ . I was trying to duplicate my desktop menu onto the mobile menu but I think I messed it up somehow. I probably should have selected an easier template to work with, this one is not as user friendly for me. Every time I create a menu, and assign, my desktop menu is messed up.
When I view your site, it looks as it should. Are you on a small screen? IS it when you are in the customizer and trying to adjust the menu it goes to mobile? If so that is because your display size when in the customizer is small enough to que the mobile menu. If that is not the issue, I’m not sure that I fully understand. I’ve attached a screenshot of desktop and then will do one of your mobile. If this is not what you are seeing please send screenshots to support@helloyoudesigns.com or attach them.
