Mobile view (Hello Rose)
QuestionsCategory: QuestionsMobile view (Hello Rose)
nhithaiphotography asked 7 years ago
On mobile view, my testimonials have huge margins/paddings that I would like to remove. Please advise how I can do so. Furthermore, is there a way to view as mobile on my desktop to make editing a bit easier? Is there an option to have a page’s layout be different on mobile vs. desktop?
http://nhithaiphotography.com
Thanks so much for your help!
Nhi
The testimonial rotator adjusts to the height of your longest testimonial and then centers all testimonials in that space. Which is why you see that large gap for some. What is best is to choose excerpts. That way each testimonial is the same height/# of words. It is a much cleaner look. Or try to use full testimonials in equal lengths.
Most browser windows have the option of viewing the site on a certain screen size. Check out the browser settings you are using, or may need to google instructions for your particular browser.
To adjust how it is displayed would be in the code. Right now it is optimized for mobile viewing and keeps in line with what search engines want for mobile browsing.
nhithaiphotography replied 7 years ago
Thanks so much for your response! I will adjust accordingly.
