Nav_Menu Block Error – Hello Coach Kadence
QuestionsCategory: QuestionsNav_Menu Block Error – Hello Coach Kadence
Sean Young asked 3 years ago
I received the following error message when trying to customize the nav links in the footer widget.
Support Team Staff answered 3 years ago
Its from that block not being supported by wordpress, even though it is a wordpress block.  If you delete the old, you can add a new and the error will go away until the next time you try to edit it.  Hopefully in the next wordpress update they will fix this error message.
