Need Help Duplicating a Page
I am trying to setup my store on my site (Hello and Co theme) and I want to duplicate the page that is titled Shop in my list of pages. It is a page that you created. But when I duplicate the page using a plugin (and I have tried several different plugins just to make sure it wasn’t the plugins problem), none of the content copies over. I noticed also that when I go into the original Shop page that you created, I am unable to edit any of the content. This makes me wonder if something isn’t wrong with the page. I know that we have seen something similar to this problem a while back, but I don’t remember what you did to fix it. Can you take a look? I know that you should still have all of my login info.
Thank you
The shop page is created automatically by woocommerce. They have shortcodes that you can use to add to a page to get the same layout. Here is a link to the woocommerce shortcodes
https://docs.woocommerce.com/document/woocommerce-shortcodes/
