No entiendo CONFIGURACIÓN DEL BLOG.
Buenos días, no entiendo que quiere decir el apartado CONFIGURACIÓN DEL BLOG, en el apartado CONSEJOS GENERALES PARA TODOS LOS TEMAS KADENCE, creo que es problema del traductor.
Do you want to use the custom blog page, or just a normal blog page? If you are using the custom blog page, you will have 2 blog pages. The custom blog page is editable and you have it in your menu. The other blog page is just an archive and not editable. You need both if you plan to use the custom. You would have the normal blog page set in your settings and the custom set in your menu.
