Problem with Mobile Version of Hello Darling
Hello! My website – http://www.thelearningeffect.com – isn’t showing correctly in the mobile version. I’m comparing the way it should look to the demo on mobile. At this point, it’s not really even navigable on mobile. Is there a setting somewhere that I’m missing that makes everything work correctly on mobile? Thank you!
It looks like the theme has been modified. There is code in your additional CSS, plugin that modifies CSS or possibly a new style sheet that is adjusting the home grid. That code would need to be removed so the theme will work as designed.
That fixed it! Thank you so much for your quick response.
I am having the same issue, could you tell me where to find the CSS code and where to change or what to take out? Thank you!
What is your URL Danielle?
With the themes the mobile only works when you keep the original design. It looks like whomever customized it did not also adjust for mobile. Mobile coding would need to be added to work with the new design.
