Removing Header and Footer
Hi! Just wondering I have a Coming Soon page up and I was wondering if there is a way to remove the header and footer from the page.
Let's start creating ⟶
If this is for Kadence, then yes, it is over in the page editor portion when editing the page, you can toggle on and off the header and footer.
