Several issues – Hello Gorgeous
I keep getting an internal server error (500 internal server error).
Also, the testimonial rotator is no longer available. Do you have an alternative?
For the server error you would want to reach out to the host and see what can be done. It will not be a theme thing. It can mean your server is busy, running out of resources, or is having some other issue finishing the request you have asked of it.
For the testimonial rotator we were hoping that the plugin author would have resolved it by now. I know Jennifer is looking into the best alternative but has not settled on one to change the themes to. Any of the ones you find in the plugin database will work with the theme though. If you need assistance styling it please let me know.
Thank you. I figured that the 500 was a server error.
