Shop setup tutorials?
Are there any shop setup tutorials? My current shop page doesn’t look like the Hello CEO demo. I’ve futzed around with the customizer settings and cannot figure out how to adjust the size of the tiny thumbnails to larger images.
In the customizer, I added a left sidebar in the layout, but how do you add a widget with information? Is there any way to add a header shop photo? Attaching my former shop look I’m seeking to achieve.
To change the thumbnail size go to Customizer > Woocommerce > Product Images > Then you can set the size you would like to show. If that gives you troubles, feel free to send the URL and a login to support@helloyoudesigns.com and we can take a look.
I've figured out all design elements (sidebar, header) however I'm still unclear how to change the thumbnail size of my products on desktop. Looking forward to thoughts!
