Sidebar + newsletter issue Hello Rosette
QuestionsCategory: QuestionsSidebar + newsletter issue Hello Rosette
thatcutedish asked 2 years ago
Hi Jennifer,
I am having an issue with the sidebar. My core web vitals are saying that I used a heading to format the text within the sidebar. So I am trying to format it back to text as “paragraph” but an “about me” button I inserted right after loses all formatting when I do so. I’m not too sure how to perform this modification?
Also my newsletter which is located at the bottom of all pages/posts through reusable blocks still does not want to get the IPad image back on top of the text instead of below, just as it used to be before the Kadence update. What can I do?
Thank you,
Emma
Support Team Staff answered 2 years ago
What is the URL to preview?  If the button is not working, that means part of the code is off, or there is code before it that is not closed.  Can you screenshot what you are using?  OR copy paste the code here?
thatcutedish replied 2 years ago
You can view the sidebar here https://www.thatcutedish.com/spicy-tuna-yaki-onigiri-with-kimchi/
The button is actually working but I am trying to change the format from H6 to regular text since Google PageSpeed Insights is telling me “Heading elements are not in a sequentially-descending order” because I used H6 instead of just text. However when I am trying to adjust it in “customize” the button loses its format. I have updated my first comment and added a print screen. I am not sure about the code, since I am doing it visually.
