split main menu not showing on mobile
QuestionsCategory: Questionssplit main menu not showing on mobile
stacu brillhart asked 2 years ago
Hi there,
My theme has a split menu on either side of the logo, but on mobile only the first menu shows. Is there a setting somewhere to adjust this? (stacihartnovels.com)
Support Team Staff answered 2 years ago
Yes, on mobile you have a mobile menu.  You would need to create a menu that shows for mobile, then select the mobile box.  It does that so you can customize the mobile output and keep it more simple than you would have a desktop menu.
