Testimonial rotater for Hello Niche theme
Hello,
I had purchased the Hello Niche theme a while back, and I am trying to add a testimonial roater on my home page, but it’s not letting me edit it.
I was wondering if there was another widget I needed to add to be able to edit it?
Thank you,
Ariana Stubbolo
If this is for Genesis, we used the Wp Testimonial Rotator, which gets the testimonials added in the plugin settings. Then you connect the shortcode or rotator block in a widget, or the page you want shown.
If this is for Kadence, you would use the testimonial block, and can directly edit in the block. The settings for styling will be over on the right when working in the rotator block.
