Testimonial Rotator- Hello Blush
QuestionsCategory: QuestionsTestimonial Rotator- Hello Blush
Jenn Loyd asked 7 years ago
Hi, can you tell me how to set up the testimonial rotator to look like the theme? How did you get the line with the name under it. A little more instruction on the set up page would be really helpful. Thanks, Jenn
Christina Maloney replied 7 years ago
I agree. When I use the plug-ins as directed, they do not match the theme demo. That is really frustrating.
Jennifer Staff replied 7 years ago
Which plugin are you having issues with?
Each plugin has different settings. We try to include a screenshot of how the widget is set in each theme. There are also plugin setups on the support site. Here is a screenshot of how this is set up
