Testimonial Rotator Won’t Show Up on Home Page
I’ve created a HTML widget to publish the short code for my testimonials rotator to no avail. The content NEVER displays on the Home page’s Home Featured widget below my products display. I’ve accumulated reviews that I’d like to publish. I’m at my wit’s end!
The rotator can be tricky. With the reviews you want to show on the homepage, did you assign them to the rotator that you are using on the homepage? If not, then the rotator doesn’t know what to pull. To assign them you go to each testimonial you want to show, click edit and scroll down the page, there will be a little box that lets you click to assign it to the rotator. If need help, shoot over the URL and login to my email at jennifer@helloyoudesigns.com
