The Links and Block Pages on Footer
The Links and the Block Pages areas on the footer both have pages attributed to them and neither are showing anything on the footer on my site.
Please email support@helloyoudesigns.com with the URL and login. Do you know if those have been set in the widget area that is represented in the footer? Sometimes it is just reselecting the menu you want to show in the nav widget.
We were able to log on and re selecting what menu you want to show fixed the issue.
