Theme Not Updating
I purchased the hello maker a very ling time ago and even paid for you guys to setup the theme on my domain. I cant remember which email I used or where to look for the purchase code. The theme has been out dated for a while now and I wanted to know what happens now. Can up get access to another theme since there are no updates for the one I purchased?
We did retire Hello Maker back in 2018. In your account area will be the last update for that theme. If you can email me possible names, or emails that you used to purchase it, I can try to locate your account so you can access the theme file. jennifer@helloyoudesigns.com
At this time Maker is still working with the latest WordPress and PHP, as long as you are running that update. But because there will be no further updates to the theme, and it will eventually stop working as wordpress updates, it is best to look at changing themes. We no longer offer Genesis themes and a few years ago switched to Kadence themes. They are much easier to work with and have a ton more features. You can see available themes here
https://helloyoudesigns.com/themes
