Wacky spaces on Testimonial Rotator
QuestionsCategory: QuestionsWacky spaces on Testimonial Rotator
foodshooter asked 7 years ago
I have 8 testimonials in the rotator – several of the testimonials have large gaps of space in them that are not showing up in the WP editor.
There is also a white gap of about 4 inches under the rotator.
Can you see what is causing these issues?
Thought I was done but this is the last thing I’m adding. Thought it was going to be super easy.
Thanks
Support Team Staff answered 7 years ago
It is from a few issues.  The first is that they are all different sizes and it keeps the title and stars at the top.  In the roator options there is a box to check to center the testimonials.  I’ve checked that, so now everything is down where it should be.
The second issue is that when you copy/pasted these in, it picked up extra code.  Example is the “Love For The Business Of Photography Workshops”  if you click over to the HTML tab you will see all the extra code, which is creating the weird blank space.  I’ve deleted it from that one, so now it appears normal.  If you go through the others that have weird space, that is what it is from.
Then once all the extra code is removed from the other testimonials that rotator should shrink up to a normal size.  Right now it is adjusting the height to be equal for your tallest rotator.  Let me know if this does not make sense.  I may not be explaining it good.
foodshooter replied 7 years ago
Oh jeez. I’m so sorry – I did copy and paste this. I should have put it into a plain test doc before putting it in the blog. That totally makes sense, I will adjust it now…
