Weird \”Slash\” Appearing in Header
There is an odd “slash” mark appearing in the very top left of the header on only the Mobile view. Desktop view looks fine. URL is reinventingsustainability.com
How do I get rid of this?
It is on both your desktop and your mobile. When I inspect it looks like it is from your ShopStyle script that you added to the site.
If the script added was not whole, that will happen. You want to make sure that it was the full < script >to end </script > with nothing before or after.
GOT IT! Thank you for the quick response; that fixed it! Really appreciate the team getting back to me so quickly!
