Yellow Highlight on Shop Categories
My categories are highlighted yellow, is there a way to not have them highlighted like the demo shop?
What is your URL? This is from the Woocommerce mark. I can give you code to change the color, or totally remove it. Which would you prefer?
birchdesignsco.com
I’d prefer to just remove the color altogether. Thank you!
You can add this to your Additional CSS in the customizer
.woocommerce mark {
background: transparent !important;
Perfect, all set. Thank you!! 🙂
