Affiliate Disclosure with Gutenberg
QuestionsCategory: QuestionsAffiliate Disclosure with Gutenberg
Rachel Hampton asked 6 years ago
Hello! I’m operating on the Hello Luv theme and can’t find where to add the affiliate disclosure. It looks like Gutenberg doesn’t have a place for custom fields. Do I need to add a plugin or something?? Thanks!
Here are some screenshots of how to access that option
Step 1 – Click the 3 dots in the editor and then click on options
Step 1 Custom Fields
Step 2 – A screen will pop up and you can select the Custom Fields Box
Step 2 Custom Fields
Step 3 – Once you select that custom fields box, it will open it up like on the classic editor for you to add in the affiliate blurb
Step 3 Custom Fields
Let me know if you have any issues.
stephwittek replied 6 years ago
I’ve actually created the custom field, it is checked off under screen options, and the disclosure is still not appearing on my site. Any suggestions? I haven’t published the blog post yet, but I don’t see why it wouldn’t show in the preview.
Support Team Staff replied 6 years ago
What is your URL and login to the site? We would need to log on and see why it is not showing. You can email that information to support@helloyoudesigns.com If the word affiliate is not in all lowercase, it will prevent it from showing, it has to be exactly like the above for the Name field.
Woohoo! That seemed to work 🙂
