Blog Page not display blog posts
QuestionsCategory: QuestionsBlog Page not display blog posts
Alba Figueroa asked 4 years ago
I have Hello Blush (Genesis) installed and the blog posts don’t display on the blog page.  You can see them individually and on the homepage but when you go to /blog nothing is there.
http://velazquezlegal.com/blog
Question Tags:
Jennifer Staff answered 4 years ago
This can be 1 of 2 things. The first I would check is if you have the homepage set right. It needs to be on latest posts and not static. That will be under Settings > Reading > Latest Posts.
The other thing it could be is that you are running version 1.0.0
If neither fixes it, you can send your login information over to support@helloyoudesigns.com
Alba Figueroa replied 4 years ago
yes, it’s 1.0.0. How do I update it?
Jennifer Staff replied 4 years ago
If you purchased on the site it should be at
helloyoudesigns.com/my-account
