Clickable Home Flexible Widget on Hello Luv
I have the standard, 4 widget setup within my Home Flexible (Hello Luv theme). Each of the bottom three sections showcase one of my services. How can I make these individual blocks clickable that will take a user to the page it addresses? Thanks
What kind of widget did you use? Is it possible to see the URL?
They’re just text boxes. I am in construction mode, so no. How else can I show you?
if they are just text boxes, you should be able to use traditional HTML code with a link info to have it link. Or add a classic button.
That wasn’t actually supposed to turn the link to a link, but show you the code I wrote. In the setup guide, at the bottom of each one are copy paste codes for links and buttons that you can add and then modify to your own links
