Colors Reverted to Default in Hello Boho Theme
QuestionsCategory: QuestionsColors Reverted to Default in Hello Boho Theme
Rita3130 asked 7 years ago
All of my colors have reverted back to the default ones. I checked Customize but it shows my colors that I have changed. Yet, for some reason when you look at the blog my colors are there.
Yes, this is from the latest Genesis update.  You will need to update your theme to the latest version.  If you need help you can send your login to jennifer@helloyoudesigns.com
Rita3130 replied 7 years ago
Thanks! I got it updated.
justsimplymom replied 7 years ago
I’m experiencing the same thing. How did you fix it? How do I update the theme to the latest version? i don’t see it on my dashboard.
Jennifer Staff replied 7 years ago
You would download it from your dashboard, then log on to your cpanel, or ftp and replace the theme file. Email me at jennifer@helloyoudesigns.com with your information.
