Excerpt Buttons
Hello! I recently purchased the Sweets Blog WordPress theme and I have noticed that the Read the Post buttons under the posts doesn’t display. I don’t see the instructions specifically mentioning how these are set up so I placed the button code in the post excerpt. Doing this, there are two buttons and one at the end of my post. Do you mind advising how I can get this button to show up after every post as it is on the demo?
The theme comes with two options, having a button or a ….. To enable the button go to Genesis > Theme Settings and click Entry Content for the limit and then use 300 to 400 for the amount. Then the buttons will show. If you pick excerpts, the … will show.
Let me know if you have any issues.
