Featured Blog Images on Top of Posts Not Showing
Hello, I am installing Hello Luv on my blog https://asprinklingofcayenne.com. All of the post data has transferred into the theme except for the top featured image. I am using the classic editor plugin and have the featured image uploaded. I also went to genesis – theme settings – featured image, and the box is checked. I also disabled lazy loading on Jetpack.
How can I get the featured images to show back up at the top of each post?
Is it that it is not showing at the top of the post? Or on the Blog and Archive pages? If it is not showing at the top of the post, that is normal. None of our themes are coded to show it on the post. This is for SEO reasons and more flexibility. It would need to be manually added to the post if you would like it to show before the post content.
If it is not showing on the blog page and archives, and you have checked all of those spot, please email your URL and login to Jennifer@helloyoudesigns.com and I can hop on and take a look
Ah, I see now. Thanks Jennifer. 🙂
I will manually add them.
