Fix for Home Services not being the same style throughout
Hello – I know we had emailed about this a while ago and you said you were working on it, but I am not hearing back anymore…
On the Home Services of Hello Boho, when using a 6 alignment, 2 of the 6 have titles located differently and also have a different effect on hover… I would really like this to all be uniform… And since this wasnt included in the live demo, I cant see how it should be other than the screenshots on the support page.
I’ve reached out to the plugin authors and have not heard back why some of those images are registered differently than others. It is not a theme fix, this would be in the plugin itself and how it outputs the links. Right now though, all of your 6 buttons are doing the zoom on hover like they should. The titles are also correctly aligned. You may need to clear the cache to see the changes.
