Hello Beauty – front page widgets not showing
Hello!
I’m setting up a Hello Beauty for the first time and I’ve never had issues with the widgets showing up before. But with this install I can’t get what I put in the widgets to show on the site. For example. I’ve added an image to one of the Home Page Grid widgets. Nothing shows. I also added an image to one of the Footer widgets, it doesn’t show. The only things I’ve gotten to show properly are the menus all in the right places. Only thing with the small nav menu is the last symbol which I’m assuming is the search icon? comes up with an error for me.
Any help will be greatly appreciated. Again, I’ve never run into this happening with any of your other plugins.
The site is at http://www.francescagraziella.com
The site looks gorgeous. Looks like this is resolved, or still having issues?
Thank you! Yes, I figured it out. I guess it’s setup so that all the widgets for a particular section have to be filled in before it populates? Anyway, that’s how it worked. The only thing I didn’t get to work is the search icon on the small nav bar it still shows as an error box for me. And when I added some test featured images to the blog posts, they look quite big. Is that because of the order? Does it have to be video, image, image in order to have the same look as the demo or did I miss a setting somewhere?
And last question I think, how do I get the pretty social share links on the blog feed under each post? And is that a custom feature of Social Warfare?
Here is the link to the setup guide for the Genesis Simple Share plugin
https://support.helloyoudesigns.com/simple-share-icons-for-posts-archives/
