Hello Blogger Affiliate Banner for Blogs
Hi! I recently upgraded my theme from Genesis to Kadance, and my affiliate headers for my blog posts are no longer showing. Everything in the backend is right according to what I used to do in Genesis. Does the affiliate banner live somewhere else on Kadance?
That was an area that was hooked into the genesis theme. With kadence you would add it as a block. Each of the themes comes with a little affiliate banner in the library that you can add to your posts. Do you have a ton of posts that need it? If there are more posts than would be easy to change to the block style, you could look into adding custom code to the functions file that will call in that affiliate bar that the genesis theme used.
