Hello Blogger Footer Not Displaying Correctly
I switched my theme from Hello Boho to Hello Blogger but the footers are still the Hello Boho. How can I change the footer to Hell Blogger?
That is one of the only problems when swapping themes. If you do not run the demo import, it will not import the footer settings. If you want to email me, I can log on and remove the boho style, and place the blogger footer up. jennifer@helloyoudesigns.com and will need the URL and a login.
