Hello Blush Demo not loading correctly
The Highlight Whats Important widget is not loading and I am unsure how to correct this. Also at the bottom of the page under blog and what’s new the words sidebar/content are broken up so it does not read correctly. Is this something that will just fix as I am replacing the demo content with my own content?
Possibly. My concern is that you mention broken up, would it be possible to see a preview? Sometimes when you do the widget import, the images that imported from the demo content will not always assign to the widget. So when it trys to pull the image, it doesn’t show. Genesis Featured Page widgets and Soliloquy will do that. Which is fine, because once you add in your own images they will show. But the broken up part, doesn’t sound right. You can also email me at jennifer@helloyoudesigns.com
