Hello CEO Installation
QuestionsCategory: QuestionsHello CEO Installation
Nichol Burton asked 1 year ago
Hello, I tried to install Hello CEO to my existing WordPress site where I already had a Kadence starter template active. I was able to install the Hello CEO template, but it was not the same steps that are listed in the walkthrough. There are several design items that don’t seem to be holding the template design. Like the header and transparent scroll on the home page. Again on the homepage under services #2, the text does not align how it should. I’m not sure what to do but I think is has to do with the initial install.
Jennifer Staff answered 1 year ago
Can you send the URL and a login to jennifer@helloyoudesigns.com I can hop on and take a look.
