Hello & Co — EnjoyInstagram Not Showing and Site Title Still Showing
I don’t know what the issue could be. I’ve reconnected EnjoyInstagram and it shows up when I’m in the customizer. Actually, my entire site shows perfectly in the customizer, but when I have a look at it in a live environment, everything’s off. Please help!
My blog — http://brittharris.co/
It looks like it is being blocked on the site. When you inspect the code, there are many errors. All look like it is google ads and something blocking access to the site. Do you have a security plugin installed? Maybe try deactivating that and see if it allows the images to load and your google ads plugin to work. If that doesn’t work, I can try to hop on and pinpoint where it is coming from.
I have WP Rocket installed. I deactivated it and they showed up. I never thought the cache plugin would've been the caused. I deactivated so many other plugins. Thank you!
