Hello Rosette Blocks – Slider Question
QuestionsCategory: QuestionsHello Rosette Blocks – Slider Question
shellybrown asked 2 years ago
When I add the Rosette Block to a page that contains the slider, the wording overlay shows below the slider.  I’m sure I am overlooking a simple setting, but can’t seem to figure how how to make it display over the slider (as pictured in the demos).  As of now, the block with the overlay and button displays below.  If it is relevant I am using the blocks with the Hello Beaches Kadence theme. Thanks in advance!
In the editor it will be below it, but the actual page when viewed will show correctly. Is that what is happening? Or on both views it is below?
shellybrown replied 2 years ago
It is displaying below it on both views. I have also tried a few different browsers just to double check. Thanks for your assistance!
Jennifer Staff replied 2 years ago
Can you email login info and url to jennifer@helloyoudesigns.com
For anyone having a similar issue – When you get a block library collection, some of them will have additional styling that needs to be added to the theme for the blocks to appear like the blocks in the demo. There will be a zip file that comes with your block collection that contains this styling. It gets added to the Additional CSS spot in the customizer. Instructions are in the setup guide for the block library.
