home close
Hi
I cannot get the third text widget in the same position as the theme guide – can you help?!
I have emailed you my log ins previously
thanks
You have 3 widgets in it, so it is flexing how it is designed. The first widget will always be 100% width, then the widgets that get added below are the ones that flex. If you would like all 3 to be on the same row, you would need to add another widget at the top, then the 3 will flex. Here is the flex image below
you star thank you
Looking at the site, everything looks good. Which section is this? I see it is home close, but that spot is empty. If it is that spot, could you place in the widgets that you would like to use so we can test what is going on?
hey sorry forgot to publish – please look now x
