Home flexible
Hi, I would like to add a different image/icon above the text in Home Flexible widget. I am not sure how to do this, which part of the code do I keep?
Thanks, Blanche
You would replace the URL that is in between <img src=”IMAGE URL HERE”> with your own image url. Let me know if you have any issues.
I am trying to add an image that I have saved on my laptop. Is that possible? Anything that I create with picmonkey or other site, has to be saved to my computer and then I don’t know how to add it, as then it doesn’t have a URL. Not sure where I can get similar images to the demo, but I don’t want clips…please advise.
Thanks, Blanche
No, you would need to add it to your media library on the site. Then once it is uploaded the media library will give you a URL and that is the URL that you would use.
