Homepage blocks issue
QuestionsCategory: QuestionsHomepage blocks issue
thatcutedish asked 8 months ago
Hi Jenifer,
For the past few days, I’ve noticed an issue with the blocks on my homepage, even though I haven’t changed anything on my end. I have blocks from both Hello Rosette and Hello Iris, so I’m not sure which one I originally used.
The problem is that a left margin suddenly appeared, leaving a gap on the left side of all blog blocks (see attached).
Could you let me know if any changes were made on your end?
Thank you in anticipation,
Emma
Jennifer Staff answered 8 months ago
This may be from a kadence update.  Not the theme adjustment.  You can add this code to remove it.
.single-content ul {
padding-left: 0!important;
