How to duplicate/clone a blog post?
Hi there! I’m wondering how I can duplicate a blog post, so that I can edit a duplicate and save the templates for future use. Thanks so much!
Let's start creating ⟶
There are a few ways, one is a plugin that will allow you to duplicate any post or page. The other so you don’t have another plugin on the site, is to save whatever post you want duplicated as a draft, then copy/paste it over into a new post when you want to use it.
