How to remove the About yourself Biographical Info under each post?
I noticed under each post it says “About Chef Elizabeth Reese” then it is blank because I didn’t add anything but the header won’t go away. I found out how to navigate to it on the backend of WordPress under “users/my profile” however I can’t see to remove the “Biographical Info” can anyone help with this?!
In the Users>Your Profile section, when I scroll down to Author Box, “Enable Author Box on this User’s Posts?” aren\’t checked.
If that box is not checked, then it is being added by a plugin. Go through your list of plugins and see which one adds that feature. If you can’t find it, shoot over the URL and login to my email at jennifer@helloyoudesigns.com
just sent you an email!
thanks!
