How to underline within blog post
QuestionsCategory: QuestionsHow to underline within blog post
Lee-Ann asked 6 years ago
Hello,
While writing on my website (I am using hello boho) I refer to other links within my article. At the moment the links are unable to be seen unless you hover over them with the mouse. I would like my links to show up with a line underneath so people know to click on them if this is possible?
Cheers
Lee-Ann
Yes, you can do that.  The other option is to also change the primary link color, so it is a different color from your main text.  That option is in the color customizer.
To add an underline add this to your additional css
a {
text-decoration: underline !important;
Lee-Ann replied 5 years ago
Thank you so much!!
