Images Not Centering
QuestionsCategory: QuestionsImages Not Centering
jonsie asked 7 years ago
I cannot get a blog post image centered.  I use the toolbar to center it, and in the preview it displays correctly. But once I save it and view my site, images are still left-justified.  When I view the html, it is adding the property class=”aligncenter”, but it is not being centered.  Ideas? Thanks!
It looks like it is from the way the image was added.  It is being wrapped in extra code, for pinterest, I believe.  If you would like, I can hop on and give you more specifics on how to fix it.  you can email the login to jennifer@helloyoudesigns.com
jonsie replied 7 years ago
Oh thank you!! I was wanting to change that plugin anyways, so I just installed a different one and it’s good to go! That was the problem! Thank you so much! <3
