Instagram Feed Not Working
I tried putting the Instagram feed as footer, however all I get is “[instagram-feed]”. When I try downloading the plugin Smash Baslloon Social Photo Feed it says the folder is already there but I don’t see the plugin.
Thank You
This will happen when there is a hiccup during install. You would need to log on to your file manager, go to the plugins folder and manually delete the plugin. You can also call your host and ask them to do that if needed. Once done, you would be able to reinstall it, connect your feed, and the shortcode will change to the actual feed.
Awesome! Is fixed. I just have to fix the sizes. I think I saw a post here about that.
