Iris Theme: Upgrading to Blocks Pro
QuestionsCategory: QuestionsIris Theme: Upgrading to Blocks Pro
Katie Macdonald asked 2 years ago
Hi Jennifer,
I think I’d like to upgrade to Blocks Pro as then I get direct form integration with ActiveCampaign (rather than needing to create a form which is slightly off design!) and I’ll also be able to add some movements on some elements.
If I do this, will I think need to redesign all the block as Pro blocks, or will more features/options become available in each of the existing block settings?
Hope that makes sense!
Thanks,
Katie
No you will not need to do any redesign, you will just have more features available.
Katie Macdonald replied 2 years ago
Thank you for confirming!
