Navigation Small Bar
Hi there!
I have the Hello Foxy theme and website is flirtyskin.com
How do I add the eNews widget inside the Navigation Small Bar as shown on your website: https://helloyoudesigns.com/?
The First Name box and Email Address box are showing up under the black box (Nav Small Bar) inside my Header: Join our tribe for business tips and downloads and I would like it all to be together on the same line similar to your site listed above.
Also how do I change the color of the text in the Navigation Small Bar?
The hello foxy theme was not designed to display that. You can add it, but code will need to be added to the style sheet for it to look like that. You can email the supportteam@helloyoudesigns.com to get a quote if you would like our team to add the code for it.
