Primary Sidebar Removal on Additional Pages for Hello Beauty Theme
QuestionsCategory: QuestionsPrimary Sidebar Removal on Additional Pages for Hello Beauty Theme
Alicia Robinson asked 7 years ago
Hi, I am trying to remove the primary sidebar on all pages of my site influencergal.org (still under construction). I was able to remove it from the homepage and most other pages, but not shop items ( http://www.influencergal.org/product/vintage-lady-lightroom-preset/  ). I want the content to span full width. How can I do this? Thanks.
Support Team Staff answered 7 years ago
Go to Genesis > Theme Settings and select the full width layout.  That will make the entire site full width.  If a page is not changing to full width it is because it was adjusted on that single page.  For that you would go to the page, click edit and in the editor change it to either default, or full width.
Alicia Robinson replied 7 years ago
My entire site was already set to full width. The shop page was set to full width as well. When I click on a product to view it, I still get the primary sidebar note. Example: http://www.influencergal.org/product/blogger-gal-lightroom-preset/ How do I fix this?
Support Team Staff replied 7 years ago
Do you have the Genesis Connect for Woocommerce installed? If not, that should fix it. Also be sure to check that you do not have the left sidebar active on that product page. If both of those are correct, please send over your login to support@helloyoudesigns.com
It’s still not working, I will send my info.
Jennifer Staff replied 7 years ago
We were able to log on and it was from the Left Sidebar being assigned on your individual product pages. We adjusted the http://www.influencergal.org/product/vintage-lady-lightroom-preset/ to be your default layout, which is full width. You would want to go back through the products that have the sidebar showing and change them to default layout, or select the layout style you would like. I also emailed you a screenshot so you can see the area that is being referenced.
