Question about newsletter widget
QuestionsCategory: QuestionsQuestion about newsletter widget
stacey weinberg asked 4 years ago
I removed all the newsletter sign up widgets off my blog site when I was first designing (Hello Blush) and I can’t figure out how to put them back on/up. Please help! Im using the Kadence builder.
Jennifer Staff answered 4 years ago
The newsletter will be added with a custom html block, then you copy/paste your code from your provider. If you are trying to add it to the sidebar, or footer you can use the genesis enews widget still, and add in your form action from your provider.
