Simple social icons in top bar and footer not showing up properly HELLO BEAUTY
QuestionsCategory: QuestionsSimple social icons in top bar and footer not showing up properly HELLO BEAUTY
Jennifer Barbre asked 6 years ago
The simple social icons in the top bar are showing squares instead of the icons and in the footer they are showing circles. The links work but the icons aren’t there.
When you go to the simple social icon settings, what do you have selected for the icon color? All of the color settings for those are directly in the widget for it. If it is still not showing after you have set the icon color, please send your URL and login to jennifer@helloyoudesigns.com
