Testimony Slides Kadence themes
QuestionsCategory: QuestionsTestimony Slides Kadence themes
Meri asked 2 years ago
Hello! how can I get the testimonial slides on the home page of the hello boss theme to go slower? How can I change the amount of time it takes before the slide changes? Hope that makes sense!
When you click on the block, over on the right are all of the slide settings. There will be a speed and transition setting you can adjust.
