Text scrambled on mobile site – Hello Blush design
My desktop version of this site looks great, but the italic wording in the headings on the homepage are being scrambled on the mobile version.
Please help!
If something is not fitting you can go to the block, click the text that is messing up, then click on the mobile icon for that section and make adjustments. When you say scrambling, is it that there is no line height? If so, you would want to remove any line height that was added to that section for mobile so it defaults, or you can adjust it to the line height you would like.
