Trouble with double featured images
I am trying to put featured posts on my homepage. I am having a problem with the formatting of the double images. I have assigned a secondary image and gone in and regenerated the thumbnails for the pictures I want. i have even tried to manually resize the pictures. I just keep getting one very large picture in the end.
What is the url to preview what is happening?
thegirlthatgoes.com Its the large picture in the middle. I just want it to be the two double pictures with the featured images
It is from the way it is added. The Genesis featured post doesn’t do the double images. That feature is only in the default blog roll. You could get the same effect by removing that widget and then showing the front page content.
Fixed it! Thank you for the assistance!
